305 V8 Rebuild...
Old May 14, 2006 | 09:57 PM
Kuhlmann11's Avatar
305 V8 Rebuild...
Just got a 1987 Trans Am, it has a 305 that is stock with a carb. I was wanting to rebuild the motor and wanted to know if anybody knew if it was a 4 or 2 bolt, any more information of any would be a help. Thanks
Old May 14, 2006 | 10:01 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
It's a 2-bolt...they didn't make 4-bolt 305's
Old May 14, 2006 | 10:15 PM
Kuhlmann11's Avatar
Thanks, Tell me any more?
Old May 14, 2006 | 10:19 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That statement is in error, I have one (Factory 1983 G20 305).
Canadian cast blocks were made in 4-bolt main orientation for Trucks/Marine engines.
That being said, you are unlikely to find one in anything other than a boat or 3/4+ ton truck or van.
Old May 14, 2006 | 10:24 PM
lasher_350's Avatar
Engine: 5.7 L98
And that's not quite a 1987 Firebird is it? Although I'm guessing someone could have swapped in a canadian cast block from a boat or heavy truck into that firebird...stranger things have happened
Old May 14, 2006 | 10:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if you want to rebuild something go find a 350 and rebuild that, it'll be cheaper and make more power
Old May 14, 2006 | 10:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You said there were no 4-bolt 305s, period. I was just pointing out that they were made. I even agreed that it was most definately a 2-bolt main block. Really the whole 2/4 bolt main thing is irrelavent for a street engine up to 400 HP and 6,000 RPM.
Badrs2810
Jun 5, 2012 09:03 PM
flaming-ford
Aug 20, 2010 03:43 AM
jo_daddy
Aug 3, 2010 09:59 AM
RiV
Aug 2, 2009 07:47 PM
TPI-RS
Mar 6, 2009 08:55 PM
