Newb head removal question
Old May 16, 2006 | 12:42 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
I am trying to pull the heads off and i removed 8 bolts, all accessories, intake manifold...now what? The thing is stuck on there like the botls were never removed. Help ASAP i need to get on this tommorow so i will have parts to finish putting it back together in the mail sometime within the next 2 days.
Old May 16, 2006 | 12:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There are a whole lot more than 8 bolts holding the heads down, so yes... it's exactly like the bolts were never removed. Take out the other 9 and you'll be able to pry it off.
Old May 16, 2006 | 01:32 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
Yea i just went out and started to look and there are 9, now on the other bank of cylinders i cant get to one of the bolts that inbetween the rockers...what do i do? Here is where i am at with the head with no bolts.
Yellow indicates removed bolts.
Old May 16, 2006 | 01:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Take the rockers off. They have to be backed off to get the pushrods out anyway.
Old May 16, 2006 | 01:44 AM
michal_larson's Avatar
removing the rocker arms make it easier...Putfile - You will lose Larson Power
what casting number are those? they look like "187"'s the bolts are under the headers
looks like a truck tbi l03
Last edited by michal_larson; May 16, 2006 at 01:49 AM. Reason: Automerged Doublepost
Old May 16, 2006 | 02:07 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
Thats not what i wanted to hear....remember i am a newb and dont want to mess with more than i have to. Then give me a run down on what is next, as in taking off the rockers, but then i have to put those back on and i have heard that there is soemthing called valve lash or soemthing like that. Im starting to get scared......
Old May 16, 2006 | 02:09 AM
you are wanting to take the heads off right?
you will have to remove the headers and remove the bottom bolts on the heads
as far as being scared, looks like your doing just fine, valve lash setting is easy
Last edited by michal_larson; May 16, 2006 at 02:13 AM. Reason: Automerged Doublepost
Old May 16, 2006 | 02:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd have to lash the valves anyway. It doesn't matter if you're a newb or not. There's only one way to get experience, and that's to do it.
Old May 16, 2006 | 02:15 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
Gimme a few minutes....i thought there were only 9 bolts to deal with...
Old May 16, 2006 | 02:16 AM
there are 17 bolts in each head
a HAYNES manual would work great for you.
Last edited by michal_larson; May 16, 2006 at 02:20 AM. Reason: Automerged Doublepost
Old May 16, 2006 | 03:54 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
Thats why i have the Haynes and CHiltons in my ceramic library. Thanks guys. Keep with me in case i run into something new. I will start again at about 5:30 pm.
Old May 16, 2006 | 07:48 AM
the first thing id do tomorrow is remove the headers, the other 8 bolts will reveal themselves. why not keep the manual in the garage where you work on the vehicle. ceramic? flower pots? I'm picturing a greenhouse. never heard of a ceramic library. sounds Australian.
the engine doesnt apear to have many miles on it, why are you taking off the heads anyway?
Last edited by michal_larson; May 16, 2006 at 07:53 AM. Reason: Automerged Doublepost
Old May 16, 2006 | 12:52 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
To see how shiny it is!
just kiddin
Even after you get the lower bolts off remember these things are not that light, you may have to yank on it a little bit to remove these things.
Old May 16, 2006 | 02:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not that light, and you have to get it off the dowel pins, too. Don't pry between the deck and the head surface if it's not coming loose, though.
Old May 16, 2006 | 05:57 PM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
Girlfriend is my second hand, she cleaned up my Edel. Performer RPM intake quite nicely. Ceramic library....the bathroom. There probably isnt over 10K miles but i am getting water in my oil and an oil leak. I think my head gasket is blown so i just decided to tear it all apart, learning experience. The timing chain cover is what is leaking the oil, one piece oil pan gasket. Any more thoughts are greatly appreciated. You guys have given me more help than anyone else that i could call to help me out. Thanks again. Be back up to the house in a few.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
