Can someone help? Got some hoses and lines, and don't know where to put them...
Car: 1982 Chevrolet Camaro Z28,
Engine: 5,0l
Transmission: TH 350
Hey,
I got some lines and hoses where I don't know where they belong.
I guess some of you know where they from. So I think I post them.
Transmission: 4L80E/4L80E
First, check out the vacuum diagram thread on the FAQ forum. It's a little hard to tell what a hose is just from seeing the end of it. I would guess the first one goes to the intake manifold, and the 2nd one to the carb, but that's purely a WAG.
2nd, the 4-pole square connector goes to the transmission for torque converter lock-up. I'm not sure what the other one is.
The fitting behind the carb should have a hose that goes to the vacuum accumulator (the large black thing on the firewall in the 1st pic).
The gray connector on a blue wire is for the electric choke.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
dhonda200
Aug 11, 2015 11:50 PM
