Mystery roller camshaft I.D.
Old May 18, 2006 | 05:51 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I recently aquired a roller camshaft which I plan on installing in a 383 O.E. roller motor for daily highway use. I have no info on the origin of the camashaft. It appears to be for a SBC GM roller motor. I have not yet instelled it in the project motor. But here is all I currently know; cam lift is .300" and stamped on the end of the cam is 158 97L
395WB 66
Does anyone Recognize this cam or part#?
Old May 18, 2006 | 07:15 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
395WB 66
Sounds like a junk stock cam.
-- Joe
Old May 18, 2006 | 08:25 AM
Sure it's not 155, rather than 158??
Old May 18, 2006 | 09:02 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
you want to run a cam with .3" lift on a 383?!?!?!
You would be making more power with that cam in a 305...
Definately want to get something better in there!
Old May 18, 2006 | 10:20 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It's .456" lift with stock rockers, but yeah..
-- Joe
Old May 18, 2006 | 12:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
-- Joe
yea...
and about a 180/180 duration and a 115 LSA
Buddy, you should definately look into a new cam. It would be a night and day difference in power, plus you might need a small base circle cam to clear the rods.
Old May 18, 2006 | 04:57 PM
ANDYZ28's Avatar
Car: 1982 Z-28
It is 158 not 155
Old Oct 26, 2009 | 04:57 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Re: Mystery roller camshaft I.D.
It tunrs out to be; 14097395 (GM HT383 crate motor) camshaft. Specs, intake lift/duration@.050 .431/196, exhaust .451/206. It is all I can afford as it was new and cheap, and gobs of torque in my cruise RPM range.
Thanks, Andy
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
dusterbd
Sep 29, 2015 08:40 AM
