Cam question
Old May 19, 2006 | 09:50 AM
me2's Avatar
me2
Transmission: 700r
Axle/Gears: ford 3.55
Cam question
TPI with rpm heads, edelbrock runners ,1988 intake.
Had a rpm cam in car for 10k miles, removed and installed smaller cam.
Still have cam but no lifters. If I reinstall the cam with new lifters, is there a chance of wiping a lobe? What lifters do you recommend?
Old May 19, 2006 | 05:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
reinstall the cam, with standard break in procedure, cover lobes in moly lube, same with bottoms of brand new lifters. Rev to 2000RPM for 20 minutes.
You might wipe a lobe anyway, kinda luck of the draw. Not a very high chance though.
lifters are lifters are lifters, I have no brand loyalty for those. Summit's are cheap as borscht.
RPM cam eh? I might recommend a different cam, to compliment your TPI setup better. Do you not like your "smaller" cam and you want to re-upgrade to the RPM cam?
Old May 19, 2006 | 05:48 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
haha, definately get some stuff to match your fueling system!
Why get components made to create max power at a higher RPM when your induction system cant do it!!
Old May 20, 2006 | 09:07 PM
me2's Avatar
me2
Transmission: 700r
Thanks for your reply.What cam would you recomend? Engine has Accel #6
computer.1.5 rocker rollers. msd ignition.rpm heads.edelblock runners,
24# injectors, block huggers with 2.5" duel exhaust.Ford 3.55 rearend.The 700r has a transgo shift kit, vet servo and governor .Shifts at around 5200 rpm.It now has comp xe256h 212-218 This setup ran better with a tb400 trans and the rpm cam before they were replaced.
Thanks for any help.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
