My starter did something scary today
Old May 19, 2006 | 08:46 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
I hit a pot hole with my car today and the wire popped out of my aftermarket fuel pump. I tried to start the car back up and it wouldn't start. When I took my hand off the key the starter kept cranking the engine! With the starter still cranking I got out of the car and tried to unhook the battery. The pos. post was so hot it burned my hands. Can anyone tell me what happened and what can I do to fix this?
Thanks,
Matt
p.s. it finally stopped cranking when it killed the battery
Old May 19, 2006 | 08:52 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Thanks,
Matt
Congratulations, your solenoid stuck. It's a common problem on Fords, but Fords have an external solenoid that's all of about $5 to replace. IIRC, your solenoid is attached to your starter and can't be purchased separately. Hope you have a warranty! Your only other hope is that somehow the solenoid terminals became bridged, like with a piece of loose wire or metal or something, and jumpered eachother, but that's a bit unlikely.
Old May 20, 2006 | 09:20 AM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Ok thanks for the reply
budowski
Carburetors
Oct 2, 2015 10:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
corey8084
Sep 17, 2015 02:56 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
Formula_88AE
Sep 3, 2015 01:47 PM
