Spark Plug Recommendation??
Old May 20, 2006 | 11:27 AM
CamaroX84's Avatar
My current setup is in my sig. If there's one thing I know nothing about it's spark plugs. Can someone give me a plug recommendation? Right now I'm running a standard AC Delco plug, and a buddy of mine said to go with a little bit of a colder plug. Any input would be greatly appreciated. Thanks.
Old May 20, 2006 | 01:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Is there some sort of issue your attempting to fix by going to a colder plug?
I use autolite 23-P's with a 0.35 gap. Seems when I go to a larger gap the plugs take a bit longer to clean up on cold start even with a full accel ign system.
Usually the right plug for your combo is found by trial and error. If your fighting a detonation issue seems droping 3 heat ranges seems to help but it's at the risk of fouling unless you get the proper gap.
Old May 20, 2006 | 02:05 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I'm running a very similar setup, and using AC Delco FR3LS per AFR's recommendation and they work fine. Is there something wrong with your plugs now?
Old May 20, 2006 | 02:43 PM
brutalform's Avatar
If you do a search on Google, for "spark plug reading" you will find some informative articles, on heat range, detonation, rich/lean etc. Also tuning recommendations, as compared to the the way the plugs look. More/less fuel, more/less timing, etc. HTH.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
