What plugs are you guys running?
Old May 20, 2006 | 04:29 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Ive been having problems lately with my plugs fowling out. Its an aluminum head 383 stroker, about 11:1 compression, speed demon 750 carb, etc. Everytime i try to start this the plugs fowl out. I leaned the carb out but the plugs are just junk. I can clean them and reinstall them and the car will run fine. These are just champion plugs i used to break the thing in. What do you guys recommend for street use? Also, im using no forced induction or laughing gas. I just want some plugs that wont give me problems. Thanks.
Old May 20, 2006 | 04:53 PM
digital_burnout's Avatar
Car: 91 camaro z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 410
i recommend running the autolite number 26's. They havent failed me yet.
Old May 20, 2006 | 06:40 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
What plugs are you running now?
No reason to change if the issue isn't plug related.
If you're running rich, fix it.
FWIW, I've always run a few ranges colder on AC's than spec'ed...from my LS5 454 to my pathetic L-6 235.
Old May 20, 2006 | 10:54 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
I just used some plain old stock champions from meijers to break it in. Im looking for some good plugs that wont fowl up so easily. The car only runs rich on initial start up, then the air/fuel ratio is perfect. Probably just exess gas during start-up.
Old May 21, 2006 | 12:02 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Best thing to do, is fix the rich start condition, my guess it is also running rich after, but your plugs will tell you for sure.
Thing is, if you run a plug hot enough to mask a rich start condition, you run the risk of detonation at higher/load rpms.
Engines are not like cut's on your chin, they don't respond well to bandaids.
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 17, 2015 02:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mx127
Aug 10, 2015 08:13 AM
