Heater hose fitting stuck in aluminum intake...help
Old May 20, 2006 | 09:32 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
I have a Performer RPM manifold that has a heater hose fitting and I can not take it out. I have used an impact gun, vise grips and have only managed to damage the fitting. Anyone have experience they care to share? Should I try sticking the intake in the freezer?
Old May 20, 2006 | 11:53 PM
EvilCartman's Avatar
Car: '82 Z28
You could also try using a little heat from a propane torch or just a good penetrating oil, I prefer Kroil. Let it soak a couple min then take a wrench or whatever you have and work the fitting back and forth. It may not move right away but it should break loose. Another way is to clamp on those vise grips or wrench and just wack it with a hammer to see if it'll break loose.
Old May 21, 2006 | 12:14 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
PB Blaster is about the best penetrant out there! Not even going to ask WHY you would want to take it out of a good intake though. I'm guessing bigger, bader intake. Right? BTW, nice factory alloy's!
Old May 21, 2006 | 12:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's a steel fitting in an aluminum manifold the dissimilar metals will have corroded each other nicely. It won't be easy getting it apart.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
