HONEST OPINIONS WELCOME
Car: 1989 camaro
Engine: 350 chevy tbi
Transmission: 350 lock up shorttail
JUST REBUILT 350 SB ADDED LIGHT CAM(480)LIFT DOUBLE ROLLER CHAIN FLAT TOP PISTONS AND HEADS WITH 202 VALVES.TOURQUED HEADS AT 70POUNDS.BUT(THIS IS THE GOOD PART)I TOURQUED THEM ONE ROW AT A TIME STARTING WITH THE MIDDLE,DO I NEED TO TAKE THEM OFF BEFORE I FIRE UP THE MOTOR OR WAS I SOMEWHAT RIGHT,ARE THEY MESSED UP NOW WHAT IS A BOWED HEAD,GEEEZ,HELP ME OUT HERE.
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
1. You shouldnt really ever talk online in all caps.
2. there is a specific pattern as to how you bolt down the head bolts. If you dont follow this, then you dont evenly apply the pressure as youre torquing the bolts down causing undue stress onto the bolts. You can find out the proper torque pattern by going to your local Auto Zone and asking them for a print out of it.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
IT'S PROBABLY NOT THE END OF THE WORLD, NOW THAT THEY'RE ON THERE, YOU CAN'T EXACTLY UNDO ANY DAMAGE YOU MAY HAVE DONE. MIGHT AS WELL FIRE IT UP AND FIND OUT.
WATCH FOR COOLANT IN YOUR OIL (MILKY, FOAMY), OR LOST OIL OR COOLANT, IE, HEAD GASKET LEAKING.
Car: 1989 camaro
well ive only put the heads on i havent put the rocker arms or liftters on yet so should i take them off and re-tourque them or leave them as is?
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
Axle/Gears: 8.8 w/3.08's with a trac-lock
take them off and retorque them, find the pattern here Small Block Chevy 267 305 327 350 400 Engine and Torque Specs
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Linson
Oct 1, 2015 09:50 PM
