gas leak around filler cap
Old May 22, 2006 | 09:01 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
when i fill the tank on my 89 RS 305 i get gas leaking around the filler neck right at the very end where the cap threads on. i did have a vaccum hose disconnected. under the hood behind the throttle body there is a vaccum connecter that has a "splitter" that splits vaccum from 1 line into 2 lines. i just replaced this item the other day. could this be caused by a lack of vaccum to the fuel tank and as a result built up pressure in the tank? car is a southern vechile so it is very much rust free and tank is like "brand new". does anybody have any idea why this was happining? it was a substainal amount of fuel. i dont want gas leaking all over my rear quater panel screwing my paint up and i cant afford to dump $3/gal "down the drain". any thoughts? is it safe to fill my tank again and not have to worry about any fuel spoilage? any suggestions would be great.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
