How to remove plug in fuel pump rod bore?
Old May 22, 2006 | 11:51 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I've got a `99 goodwrench 5.7 that the previous owner was running with a fenderwell mounted electric pump. I'm ready to ditch the puller and go to a mechanical pump, but the pump rod bore appears to have a plug in it, hollow on the pump end and closed near the cam. This motor was probably a LO5 replacement and I'm thinking this plug was factory installed. How can I get this puppy out? It looks to be a few inches long so it probably won't come out on the cam end. The hollow end is about a half inch up the bore.
Old May 22, 2006 | 02:22 PM
Vader's Avatar
That's a new one on me. Is the plug perhaps retained by a bolt in the lower RF corner of the block?
Old May 22, 2006 | 02:24 PM
Drill a hole in it, use a slide hammer.
Old May 22, 2006 | 02:55 PM
naf's Avatar
naf
It's a new one on me as well. The fuel pump well is completely dry, so the plug has prevented any oil from draining down. Plug does not appear to be retained by a bolt. I pulled the "smog" pump bolt out, if that's what you're refering to, then tried to pry it out with a driver but there was little to grip. I hesitate to drill it as the closed end seems pretty close to the cam?
Old May 22, 2006 | 06:03 PM
Vader's Avatar
Is the engine still in the stand? Pull the cam and drive the **** outta there - It should pass the front cam bearing with no trouble. Fishing it out could be a different story.
Old May 22, 2006 | 06:34 PM
naf's Avatar
naf
Unfortunately the engine's already in the car. I'm thinking maybe tapping it and pull it out by the tap. When I put it in, I figured the electric pump was because the original cam was missing the fuel pump lobe. Next time I'll know to check.
Old Aug 17, 2006 | 10:28 AM
naf's Avatar
naf
Wanted to close this one. Upon further investigation I found that the bore is not plugged, it just hasn't been bored completely for a pushrod. Why it would be step bored (1/2 inch diameter at bottom for the first inch then maybe 3/8 inch diameter for another couple inches) is beyond me but apparently this is pretty common with these one-piece rms truck replacement engines
Old Aug 17, 2006 | 10:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
so... you drilled it out?
Old Aug 17, 2006 | 12:33 PM
naf's Avatar
naf
No, engine is in car. I'm going to learn to live with it and eventually upgrade the in-tank pump. It's in an 87 LG4.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
NBrehm
Aug 25, 2015 11:49 PM
92camaroJoe
Aug 13, 2015 06:07 AM
