Rough Idle, Help
Old May 22, 2006 | 03:09 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Rough Idle, Help
2 weeks ago my ICM went up and I got stuck on the side of the highway . So I had the car towed and the next day I installed a new ICM and all has been well. When I installed the ICM I didn't have any dilectric(sp?) grease, so I just put it on and went on my way. Well, I've been worrying about it, so on saterday I took the dist cap and ICM off. I gooped up the bottom of the ICM with dilectric grease and put everything back together. Now my car idles funny and doesn't quit have the same pickup/power. What did I do to mess this up?
Old May 22, 2006 | 03:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
maybe it got a crappy connection when it was reinstalled...
Old May 23, 2006 | 12:48 PM
krisb410's Avatar
I guess it could be a crappy connection, but I really don't think that I could even screw that up. It seems to have gotten a little better in the past day or so. Could it be possible that I somehow screwed up the cap or rotor? I'm really not sure what could have happened.
Old May 25, 2006 | 05:05 PM
krisb410's Avatar
Newest update.
Yesterday I took the cap off again. In the process of removing a plug wire, it pulled the brass piece it connects to out of the cap. Is that a culprite? I did take the ICM off and whiped away most of the dilectric grease (I really put way to much on in the 1st place). But when I reassembled everything. The car hasn't changed a bit. It kinda feels like a miss when I'm at idle, but not while I'm accelerating. But when I get to speed, be it 35 or 60, it seems like somethings not quit right. Can anybody please me. It's really annoying. Should I just go get another cap/rotor? I just put these ones on there in January (Accel) a long with wires and plugs.
Kris
Old May 25, 2006 | 05:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Just tossing things up in the air, but did you possibly knock a vac line off while you were in there pulling things apart?
Old May 28, 2006 | 08:19 PM
krisb410's Avatar
84z28350, it was a vacume leak. I would have never thought. You my hero
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
