stock 86 305 TPI cam specs
Old May 22, 2006 | 08:51 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
anyone know where i can find out this info. i did a search and all i found was people asking what they should use for replacements. i wanna know the stock number so ill know how much of a jump in lift and duration im gonna be gettin.
Old May 26, 2006 | 10:33 PM
Vader's Avatar
1986 305 TPI 190 hp / 285 lb/ft Tach: yellow 4500 red 5000
Code:
						ACTUAL
Valve Lift: intake     .350			.360
            exhaust    .385			.388
Lobe Lift:  intake     .233			.236
            exhaust    .256			.258
Duration:   intake      320º			 226º
(crank)     exhaust     320º			 245º
Duration at
.075 valve lift        179º / 194°	    180º / 195º
Overlap at
.075 valve lift           4º
Accel rate above
.075 valve lift	   .00491"/deg.
Lift at TDC            .085"
Old May 28, 2006 | 02:11 AM
F-Bobby's Avatar
thanx dude. exactly what i was lookin for.
Old May 28, 2006 | 11:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 86 TPI cam is the flat-tappet version of the TBI peanut cam. It was the same cam used in LG4 engines. I dont know how you can mention this cam and a jump in lift and duration in the same sentence. This cam is horribly small.
Old May 29, 2006 | 02:23 PM
F-Bobby's Avatar
well this cam is in my friend 86 iroc and we are puttin in a cam from my old 355 in it to wake his car up. its a mild street cam but will do a ton more for his engine then it ever did for mine.
Old Jun 3, 2006 | 05:03 PM
Kevin91Z's Avatar
As long as your old 355 cam is a flat tappet, and you keep the lifters on the same cam lobe as they were installed in your engine, you can do that.
Mismatching lifters is a quick way to wipe out a cam lobe.
Old Jun 3, 2006 | 05:10 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It is also the same cam that comes in the 305/350 TBI truck engines. Its a WIMP!
jaridjohn
Jul 8, 2024 03:49 PM
st.evel07
Aug 13, 2015 06:15 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 6, 2015 04:20 PM
