torx bolts
Old May 22, 2006 | 10:10 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
torx bolts
has anyone had trouble with the torx bolts on the intake, valve covers, ect.? i tried to take off my intake and valve covers and some of the bolts rounded off. now i cant take the bolts out!
Old May 22, 2006 | 10:20 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
ughh yeah that's a bad spot. A normal bolt and you can get a socket made for grabbing them.. Maybe you can chisel into the bolt and use the chisel to push it loose? I've done that a few times.
BTW, I see you're in Antioch, I'm in concord.
Old May 22, 2006 | 10:39 PM
G-Ride14's Avatar
Car: 1988 GTA
yea I saw u were from the bay area but didnt know where. I was gettin it ready to go to sac... but now i got to deal with this
Old May 24, 2006 | 12:30 AM
Car: '72 Chevy Nova
Transmission: TH350
Did you get them undone?
Old May 24, 2006 | 12:32 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
take an oversized torx and hammer it in there to get a grip and then shop for new hardware
Old May 24, 2006 | 05:24 PM
G-Ride14's Avatar
Car: 1988 GTA
i got them off today, used a chisel. took a while though.
Old May 24, 2006 | 05:46 PM
JB22's Avatar
I had the very front bolt on the drivers side of the engine I couldnt get out. It was siezed into the manifold. It rounded off and I couldnt get it. I ended up taking a cutting wheel to it and milling away the whole head of the bolt to get it out. took about 20 minutes, but I got it
Old May 24, 2006 | 05:53 PM
Vader's Avatar
That's what happens with a cheap, knock-off driver or bit. Genuine Torx licensed tools don't do that. Domestic and imported wanna-bee tools are not quite the right size and drive lobe configuration (since that would be a patent licensing violation) and can allow damage.
A proper Torx drive and fastener will sustain both higher continuous and peak moment drive force than a similarly sized hex recess (Allen head) fastener. The cheap tools are what give the system a bad name. If you use Apex drivers you won't have that problem.
Old May 24, 2006 | 06:28 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Whenever I have a bolt like that strip out, I just grind in a slot with a dremel and a cut off disc, and get the bolt out with a flathead screwdriver. Give that a shot next time.
Old May 24, 2006 | 06:59 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It's a VERY tight area to work in with a cutoff wheel. Some of those bolts you barely see, let alone get at with a dremel.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
