383 cam dyno results
Old May 23, 2006 | 09:35 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
If you don't have Chevy High Performance mag...I will post some results I thought were interesting.
Here is the setup:
383, 11.5 compression
TFS 190cc heads
1 3/4" long tubes
Edelbrock Air Gap dual plane manifold
750-cfm carb
91 octane
160 degree H20 temp
Max timing-34*
Cam info with peak hp and torque numbers:
-Comp 12-408-8(206/212 @.050).....416hp @ 5000 rpms, 483 ft lbs @ 3800 rpms.
-Comp 12-423-8(224/230).....462hp @ 5500 rpms, 486 ft lbs @ 4100 rpms.
-Comp 12-443-8(242/248).....509hp @ 6100 rpms, 508 ft lbs @ 4500 rpms.
-Comp 3311SHR110 (206/206).....442hp @ 5300 rpms, 495 ft lbs @ 3700 rpms.
-Comp 33145SHR110 (224/224).....454hp @ 5500 rpms, 488 ft lbs @ 4000 rpms.
-Comp 3317SHR110 (242/242).....498hp @ 6000 rpms, 497 ft lbs @ 4500 rpms.
All cams had a LSA of 110.
However, would a 112 lsa be better for an automatic?
Old May 23, 2006 | 09:46 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Hmmmm...thats promising. I don't think 112 would benefit an auto anymore, EFI but not the tranny (could just be a WAG)
Old May 23, 2006 | 10:25 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I've heard that the 112 LSA would be better for the auto b/c of the wider torque band.
Old May 24, 2006 | 10:46 AM
Guest
Guest
Posts: n/a
Did they happen to print a chart, or graph that shows the rpm range vs power?
Old May 24, 2006 | 12:16 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yes they did....do you want it....if so I can try and scan it for ya'll.
Old May 24, 2006 | 12:23 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Interesting in that the torque did not very a whole lot just moved up and down the rpm range depending on the cam. Another point of interest is the dual pattern cams did better in the single pattern in the test.
Old May 24, 2006 | 04:58 PM
Guest
Guest
Posts: n/a
Thats generally true, on most heads I've seen.
I'll see if I can find the rag at the store.
Old May 24, 2006 | 08:33 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Pics added
When they come up...they are small but just click on the bottom right of the pic and they will blow up!! Enjoy!
Attached Thumbnails 383 cam dyno results-scan0001.jpg   383 cam dyno results-scan0002.jpg
1984HO
Mar 19, 2021 11:59 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
