i turn my key and it wont let me crank
Old May 24, 2006 | 06:51 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
okay so after spending 3 hrs in LTI fixing my damn starter solenoid and a bad ignition wire, i went home and noticed that my high beams were on so i got under my steering column and tried to click it manually (keep in mind my highbeam function on my lever doesnt work ). While i am down there there was this stupid clip that was in my way, so i said ugh i'll move it out the way. The clip came off completely, i know it was holding some sort of cable. So i go back to turn my car on and it will let me go to the on position but not past it where it will crank. Like if something is stuck, so i take the steering column down, saw the link that moves in and out and it seemed fine. I tried to put the key in and start it, and vuala it cranked.. does anyone have a clue where this clip goes?, the clip is some sort of wierd half circle, anyone know what im talking about? i can try to get a picture if that helps. What would cause the ignition to not go past the on position?
Old May 26, 2006 | 10:37 PM
Vader's Avatar
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
92projectcamaro
Aug 6, 2015 01:20 PM
