SMOKE AT START-UP
Old May 25, 2006 | 09:16 AM
chevyschofer's Avatar
Car: 88 iroc
Engine: 5.7 350TPI
Axle/Gears: 373'S
SMOKE AT START-UP
WHEN I FIRST START MY CAR, I GET A FEW SECONDS WORTH OF SMOKE. I LOOKS KIND OF WHITISH-GREEN. I WAS WONDERING WHAT THAT COULD MEAN?
Old May 25, 2006 | 09:28 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Wiesbaden, eh? My daughter was born there while I was stationed in Mainz.
White smoke indicates coolant in the air/fuel charge. Sounds a whole lot like a cracked head.
Old May 25, 2006 | 09:32 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
White smoke is burning antifreeze or condensation.
A puff of blue smoke at startup is very common on higher mileage engines, just the valve stem seals gone.
Old May 25, 2006 | 10:31 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
yeah its the stem seals.... really not that big of deal easy fix just takes a tad bit of time.
Old May 25, 2006 | 10:50 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Not if its actually white smoke. Most definately the valve seals if its blue though!
Old May 25, 2006 | 05:25 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
white gets too often confused with gray which could be residual fuel or running a bit rich. happened to me for awhile til i had it tuned...
Old May 25, 2006 | 06:20 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
It's not a cracked head, or antifreeze in your combustion chamber, or else it would ALWAYS make smoke.
Check again for the color, if it has a blue hue to it, I will put money on it that it is the valve stem seals.
BTW, we should just make a sticky that reads "IF YOU HAVE SMOKE AT STARTUP READ THIS!"
Old May 25, 2006 | 06:54 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Ha, I agree. It should be split up into the many colors and smells that come out.
Old May 25, 2006 | 06:59 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
there really are not to many colors... smells yes lol.. An easy way to check what it is is to check the plugs... if they have oil on them then it is the valve seals or the like... plugs can tell you alot about what is coming out of your exaust.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
