compression loss?
Old May 25, 2006 | 05:16 PM
91sleeperRS's Avatar
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
compression loss?
i brought my 91 RS (305ci) to a mechanic. he has done a valve adjustment so far. but today he said that he found i have a loss of compression in two of my cylinders on the passenger side, so the car is only firing on 6 of 8 cylinders. what causes this ? i dont want to be uninformed, but i dont want this mechanic to "take me for a ride"(pardon the pun). any help on this would be greatly appreciated.
Old May 25, 2006 | 05:19 PM
If they are 2 adjacent cylinders, then it's often a sign of a blown head gasket.
Why is the car at the mechanic getting compression-tested in the first place? That's kind of like root canals or something; while it may be useful and necessary and occasionally even desirable, people don't ordinarily just decide on a lark to casually have it done. Something wrong with how it runs?
Old May 25, 2006 | 05:20 PM
Raiderfan's Avatar
Car: '92
Don't get scamed on a new rebuild.
Buy a tester and check it yourself.
Search here or anywhere on the net for a how-to...........
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Just because you have a compression loss doesn't automatically mean you've got two dead cylinders. If the leakdown test and compression tests exceed "specs" then you're supposed to do something about it.
Think of all the things that retain compression; valves, head gasket, and piston rings. These three things are the most common (in no order) and many more things could affect compression and leakage... But focus on those. Basically, the most effective method to determine what exactly is wrong with your car is to DOUBLE CHECK the problem and then remove the head. There's a trick about putting a piece of paper up to the tailpipe when the car is on and if it sucks it back in then you've got a burnt valve- but I've never actually heard of anyone confirming a burnt valve using this method.
If you love your mechanic as much as your car, go ahead and let him work on it. If you're short on money and not afraid to get your hands dirty- yank that head after confirming his findings.
You're not burning any oil or coolant, are you?
Old May 25, 2006 | 05:31 PM
Engine: L98/TPI
Axle/Gears: 3.45
im not burning oil or coolant. my engine troubles started out with a loud ticking noise in the engine. i tried to work on it myself, but i couldnt fix it, so i decided to bite the bullet and talk to the professionals. i dont know why they tested the compression in the first place, but all i know is i want my baby back on the road, while gaining a little wisdom along the way. thank you for the quick responses.
im not sure if the cylinders are adjacent or not.
i really hope its not the piston rings!
the previous owner rebuilt the engine recently before i bought it. maybe thats part of the problem? maybe he didnt do a good enough job. compression is just Greek to me.
Old May 25, 2006 | 05:37 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
long story short: you hear something wrong, the mechanic knows what it is but wants to feed you lines about what you "should" be looking at. you spend a grand fixing it, he gets paid. win-win situation right? or wrong? take a step back and see what's really going on.
get a compression tester, they're like $10 at Harbor Freight or you can even rent one at a parts store. they come with instructions that couldn't be easier.
Old May 25, 2006 | 06:42 PM
Raiderfan's Avatar
Car: '92
Hows the oil pressure?
You need 10 lbs. for every 1000 rpm's in a sbc.
And check the exhaust manifold's bolts, if they are loose a "ticking" noise will be present.
Old May 25, 2006 | 06:49 PM
Loud "ticking" noise often is created by compression exchanging between 2 cylinders.
Definitely get a 2nd opinion, or test yourself, or whatever, before just tearing into it or allowing someone else to do the same.
Old May 25, 2006 | 07:14 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Can't stress it enough to get a second opinion at the minimum!! Especially when a thousand dollars of work is on the line lol
Old May 26, 2006 | 05:09 PM
Engine: L98/TPI
Axle/Gears: 3.45
the guy from the shop calls me today and said it was he was going to replace the valves in my passenger side head, and send it to the machine shop, for a low low price of $1800. i said "there's no way im going to spend that on a 305"
he said alright, come pick it up. so i did and it runs just as crappy as it did when i brought to them (i paid them about $700 for work so far). that dude was totally trying to rip me off i know it. i could buy new heads for half of that. the car also shut off on me 4 or 5 times driving it home from the shop. the oil pressure was pretty low and i noticed a significant decrease in power than normal also.
Old May 26, 2006 | 05:14 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
$1800 to swap some valves!??!!?!
you can go buy a pair of complete AFR heads and still have beer money left over for that price!
Old May 26, 2006 | 07:02 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Old May 26, 2006 | 07:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not really that much of a savings though, he still needs them installed.
Old May 26, 2006 | 07:10 PM
Engine: L98/TPI
Axle/Gears: 3.45
it cant be that hard to bolt on some heads right?
Old May 26, 2006 | 07:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Mostly it just takes some time.
Engine: L98/TPI
Axle/Gears: 3.45
oh okay. i think thats what im going to do. just get some new heads. or i might dog that 305 till it blows and get a 350. who knows.
Old May 26, 2006 | 07:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The problem with that is that you never know where you and the car will be when it finally blows.
Old May 26, 2006 | 07:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
True but the tow home would probably still cost less than any temporary repairs!
Just make sure you always got your cell phone with ya!
Old May 26, 2006 | 07:55 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
what all did they do, and what's the labor rate you're being billed at?
Old May 26, 2006 | 08:12 PM
Raiderfan's Avatar
Car: '92
valve adjustment and a bunch of bs = way too much..........
Bro, try and find someone who can help you at no charge (guys like us) in your area.
That's your best bet, otherwise you will get reamed with no lube......
Old May 26, 2006 | 10:25 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
to change valves and machine the head which I assume to mean just shaving a small amount to make sure it is flat is very easy fairly cheap work. at least cheap compared to 500bucks worth.
and what the hell 700 bucks and not a fix yet? what is he doing? charging you labor, beer money, money for meth, plus a few nights for him in a hotel plus some more money to rent a hooker for a few nights?
I would ask for reciepts to see what the heck he is spending all that hard earned money on.
RedLeader289
May 28, 2019 01:47 PM
FormulasOnly
Jul 23, 2018 08:47 AM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
WhteRbt
Sep 21, 2015 09:48 AM
