GM performance parts distributor?
Old May 25, 2006 | 09:57 PM
Bane's Avatar
Has anyone ever put a GM performance parts distributor # NAL 93440806 into their LG4 engines? Will it cooperate with a 1405 edelbrock carb?
Old May 26, 2006 | 09:57 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
It won't cooperate with the computer. It is vacuum advance. Is your LG4 stock?
Old May 26, 2006 | 10:00 AM
Bane's Avatar
the engine is mainly stock right now, but i am putting on a new edelbrock carb and intake and need to find a distributor that will work with the two.
Old May 26, 2006 | 10:07 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
what are you changing the carb for?
Old May 26, 2006 | 10:08 AM
Bane's Avatar
just to try something new.
Old May 26, 2006 | 10:15 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I would save your money. The Q-jet you have on there is better than the edelbrock. Just change the intake if you want. But the stock intake is also pretty good. If you want to spend some money and help out the LG4 put header and a complete new exhaust on it. Then upgrade the aircleaner with a dual snorkle (ebay) or an open element. You will notice "real" difference for your money. If you want to get your hands even more dirty, replace the cam. LG4 cam is pathetic. But the carb and intake are definitely not the LG4s weak links. Exhaust, air cleaner and cam, in that order.
Old May 26, 2006 | 10:26 AM
Bane's Avatar
I'm told that the q-jet is a good carb, but to be honest with you, my q-jet is 20 years old, its never been rebuilt and i just want to try something new. A guy i work with is making a 1923 roadster with a 283 and he swears that the edelbrock is a great carb, so i want to give it a chance. I still dont know what to do about the distributor though. Whats the best brands? whats the best distributor?
Old May 26, 2006 | 10:30 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I would go with the GM Performance one.
Old May 26, 2006 | 10:31 AM
Bane's Avatar
will it mesh with the edelbrock carb? or am i going to have some computer problems?
Old May 26, 2006 | 10:54 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
as long as its the old style vacuum advance it should work. jegs also sells a fairly cheap vacuum advance hei distributor.
Old May 26, 2006 | 11:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only computer problem you're going to have is a constantly glowing SES light and an automatic transmission torque converter that won't lock, eventually burning out the 3-4 clutch pack in the transmission.
I'd have to echo the q-jet recommendations. "Trying something new" that someone "swears" about is a receipe for disappointment. Not that it won't "work", it just won't be any better and will probably be more trouble and in the end won't work as well.
But, hey, it's your car and your money (I assume).
86IROC112
Aug 17, 2015 07:57 PM
86IROC112
Aug 17, 2015 02:00 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
