vac line at back of manifold
Old May 25, 2006 | 10:05 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
where does the vaccum line at the back of the manifold run too , its right behind the carb just before the distributor
Old May 25, 2006 | 10:53 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
power brakes
Old May 26, 2006 | 04:18 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
vac line at back of intake manifold
does it run straight to the power brake control or does it split off , becuase on mine the person who had the car before me hacked it all to crap and now im trying to find out where everything should go.
Old May 26, 2006 | 04:28 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It doesnt matter what it goes/went to...
Vac is vac.
It is most common to have the brake booster run from this location, but it can be run from either the vac port on the back of the carb or the manifold.
One thing that should be kept in mind is to never split the vac source that runs the booster. use a different vac source if you need to tee of to run multiple things.
Old May 26, 2006 | 05:14 PM
nameinuse's Avatar
On my van it feeds cruise and hvac.
9192camaro
16
Feb 3, 2019 12:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
wayshegoes
Aug 17, 2015 12:00 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
