engine help? 3.1 v6
Old May 26, 2006 | 12:08 PM
hayford1991's Avatar
Car: 1991 camaro rs
Engine: 355 sbc
Transmission: tremic 5 speed manual
engine help? 3.1 v6
hi i have a 3.1 v6 in my 1991 camaro and a couple weeks ago i had to replace the intake gasket so i took it apart replaced it and put it all back together but now with the vacum leack is gone the engine is scruing up it idles fine but when i give it gas and run it at about 3500 rpm it leans out it pops and cracks but once i get off it works fine only happens under load or high rpm sombody [plz help i ran out of ideas] thanks fellow thirdgenners.
Old May 26, 2006 | 12:44 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
double check to make sure you got all the vacuum lines hooked back up, especially the one for the fuel pressure regulator.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
