piston rings
Old May 26, 2006 | 11:40 PM
invaderzim1915's Avatar
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
piston rings
How hard is it to change piston rings on a 350? I maybe buying a Camaro that needs it and trying to find out if I could do it in a weekend or if I need to run it to my friends shop. thanks
Old May 26, 2006 | 11:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
To change the rings, the entire engine needs to come apart and the block should be rehoned.
Old May 27, 2006 | 06:57 AM
ede's Avatar
ede
to change the rings isn't hard or very time consumming. everything else associated with doing it is, like R&R the engine, cleaning and inspecting parts. no one would simply change the rings and not replace alot of related parts and there is machine work that ought to be done too.
Old May 27, 2006 | 11:44 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yup, it's all that engine and car in the way between you and the rings that's the problem, and you'd be a fool not to replace the bearings, etc. while it was apart.
You'd have a healthy amount of downtime to look forward to while you rebuilt the whole thing. If you've never done it before, you could maybe remove the engine in a weekend.
Why do you say it needs rings?
Old May 27, 2006 | 11:29 PM
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
I am buying this from a guy and trying to find out how much it will cost to get it running good and he said that the car is very very sluggish, and smokes some and I think that it sounds like the rings are burnt and I am just thinking that it may be best to just rebuild the hole thing I will have 1k to do it with any one know where to get a good rebuild kit and how much and what would be a good use to improve the motor it is a 350 with a manual trany I have a new clutch master clutch I am going to put in and I already am putting new plugs and wires so what else
This is the kit i am planing on geting let me know if there is a beter one out there
· Moly Deep Oil Ring Groove .200
· Federal Mogul recessed head Pistons
· Clevite Rod Bearings
· Clevite Main Bearings
· Clevite Cam Bearings
· Melling Oil Pump
· Federal Mogul Camshaft
· Federal Mogul Lifters
· Melling Timing Components
· Pioneer Frost Plugs
· Felpro Gaskets
$532.23
Old May 28, 2006 | 01:22 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
so, throw in hottank, boring, and your parts, and add a fudge factor, and you're just over $1k. Sounds good.
A summit kit would be about the same quality level, and might save ya a few bucks. I'd seriously consider getting a kit without a cam, and buying that seperate. None of those parts you listed would make your car slow, except for the cam. It's worth the extra $50 or so to upgrade to a cam not in a "package deal".
Old May 28, 2006 | 09:08 AM
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
ok i am new here so what is a fudge factor and hottank and thanks for the advice on sumit
Old May 28, 2006 | 10:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
hot tank = Your engine rebuilder/machinist has a big dishwasher, meant for engines. It gets them clean. Roughly $40 to toss something in it.
fudge factor - this isn't specific to cars, it just means a screw up factor. Budget whatever you think the rebuild is going to cost, then double it. When you have more experience you can foresee all the unknowns, and get more accurate, but in the beginning, you don't know all the little things that will come up, so your rebuild is going to cost a lot more then you think it will.
Old May 28, 2006 | 12:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I have a feeling that kit has a flat tappet cam. You'd want something with a roller cam anyway.
Old May 28, 2006 | 08:51 PM
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
ok what do yall think about this kit
Engine upgrade and rebuild kit
Speed Pro Forged Flat Piston and Moly Rings kit
Competition Cams Xtreme Energy Cam and Lifter Kit
Moroso Drag Racing Oil Pump
Fel-pro full Gasket Set
Clevite Camshaft Bearing set
Pete Jackson timing components
Pioneer Freeze Plug
$1000 us
I think it is worth waiting another 2 weeks to buy it and it will leave me with 500 left to take care of the other problems or will I need more
Old May 29, 2006 | 02:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why do you want forged pistons? That second kit also probably has a flat tappet cam.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
