Std. HEI on TPI?
Old May 28, 2006 | 08:15 PM
koll's Avatar
Car: 1991 Pontiac T/A Vert
Std. HEI on TPI?
Ok. this is really starting to **** me off. No matter what, my car (with ESC unhooked) will rev to about 1500 then itll load up (backfire and shake) like its retarding the timing. Right now I cant hook up the ESC because it wont even idle (itll start to fart and then die).
What if I were to just take off the coil and normal dizzy and replace it with a standard HEI (like this http://www.performancepartscanada.co...es/59107C.jpeg )
Would that work or is this a horrible idea?
Old May 28, 2006 | 09:19 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I imagine it would work.
But then you start messing up other things...
Like if it detonates and the computers trying to pull some timing and nothing happens. I imagine the computer could get a bit hairy...
Old May 28, 2006 | 10:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That's vacuum advance distributor, and no it will not work on TPI. Its only for carbs without computers. You need an '88+ EFI distributor for either a TPI or TBI engine.
As for your problem, it sounds like a bad ignition module, bad pickup coil, or the spark plug wires are on wrong, or some other wires are open or shorted.
fbirdroller
Sep 2, 2015 10:27 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
midias
Aug 15, 2015 05:07 PM
Sanjay
Aug 12, 2015 03:41 PM
