Ignition issues
Old May 31, 2006 | 12:32 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Ignition issues
Ive been havin problems with the bird for a while, the other day it cranked and wouldnt start. I let off and it wouldnt crank again i thought it was a wiring issue so i rigged the key so it was stuck forward and played with the wiring to the starter, i eventually got some smoke from somewhere. Now it doesnt respond at all when you turn the key, and when you jump the solenoid it spins the starter but it doesnt engage to the flywheel. Any help or direction with this would be great.
Old May 31, 2006 | 12:53 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
sounds like its time for a new starter...
Possibly a sticky solenoid, but to replace the solenoid is almost the price of a whole new starter.
I would say drop it out and at least take it in and have it tested.
Old May 31, 2006 | 01:13 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Well the starter and solenoid are both less than a year old.
Old May 31, 2006 | 07:13 AM
89RS&98Z28's Avatar
Car: 1989RS////1998Z28
Engine: 305////350LS1
Transmission: 700R4////4L60E
There is the off chance you got a bad spot in the flywheel, but I would pull and check starter.
Old Jun 1, 2006 | 06:41 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Well i don't think its the flywheel either. Im sure i burnt something out holding the key forward too long just not exactly sure what yet.
Infested
May 22, 2018 11:56 PM
WIzmo
Aug 30, 2015 02:30 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
