New HEads?
Old May 31, 2006 | 09:17 PM
L.I.N.Y.92CAMARO's Avatar
New HEads?
Im looking into buying new alum. heads but im unsure of which ones to buy my engine consists of:
Goodwrench 350 short block with 40,000 miles
Cast aluminum pistons
4 bolt main
HEADS
L-98 Cast Iron "083" casting corvette style from TPI 350 completely rebuilt.
1.94/1.50 valves
Hi-Compression 64cc combustion chambers
3 angle valve job
New springs, valve seals, guides
Milled and magna-fluxed
VALVE TRAIN
Compcam extreme energy XE268H (PN# 122422) (268/280) (224/230 duration) (.477/.480 lift) (110 degrees LSA)
1600-5800 rpm range
Compcam push rods, double roller timing chain set, lifters.
INTAKE
Holley Street Dominator intake manifold
Holley Street Avenger 770cfm carb
EXHAUST
Hooker Shorty 2055 Headers
Single 3"cat
3.00" Flowmaster catback exhaust
IGNITION
Summit Billet aluminum HEI vacuum advance distributor with 50,000 volt electronics
Summit custom advance curve kit
Accel 300+ Spark plug 8.8mm wires.
Also can i reuse the parts from my old heads like the valves and valve guides or just buy new and which ones should i get if buying new?
Also Is there anything else i can upgrade or do different to get more power from this engine? Its my daily driver so nothing crazy but i want to get more power out of it.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
