Any suggestions on rebuild
Old Jun 1, 2006 | 09:17 PM
'89 Iroc's Avatar
I just bought an 89 Iroc a couple days ago and it just started knocking. It has 193000 miles on it, So i knew i was going to have to rebuild. I am on a budget and wanna know how to get the most out of this engine without spending thousands of dollars. By the way, it is stock 5.7 tpi with the auto tranny.
Thanks in advance.
Old Jun 1, 2006 | 09:22 PM
riotpolice75's Avatar
depends. what do you want it to do? how far into the engine are you prepared to go?
Old Jun 1, 2006 | 09:40 PM
'89 Iroc's Avatar
Doing most of the work in my garage is my main objective. And when I am done, I want something I could drive everyday if i had to. Oh and I dont wanna a stock mustang showing me up? lol
Old Jun 2, 2006 | 12:51 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
You will need to rebuild the bottom end. Depending on whats wrong that can be decently cheap or pretty expensive. Getting more power obviously comes from the heads and cam.
I'd find out whats knocking and see what the bottom end needs. Do a compression test and see how bad the rings are. When the bottom end is solid get a valve job and since the cam has that many miles on it, get a slightly bigger cam. Throw it back in, put a decent set of headers and a good exhaust on it and you will be more than happy.
Then of course you should start to tune it to get the most from that cam...
Old Jun 2, 2006 | 05:02 PM
'89 Iroc's Avatar
It hopefully isnt anything major the car doesnt smoke; when started or when you get on it. It has great oil pressure. I believe someone has been in the engine before. The valve covers and intake are all powder coated and looks good. I am hoping bearings are the problem and the rings, pistons pushrods are all ok. Know more when i get into it. By the way what would be a good cam Thanks?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
R13_Braz
Sep 18, 2015 05:00 PM
eduardosac
Sep 16, 2015 02:18 PM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
