Hotcam VS 'XXX'
Old Jun 2, 2006 | 03:27 PM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
Hotcam VS 'XXX'
I am doing a cam swap in my 91 6 speed vette. I am doing an LT1 intake conversion to my L98, and I've decided to do a cam at the same time. I was pretty seriously considering the Hotcam because I have the LT4 valve springs and rockers, but recently I have been giving a lot of thought to a cam from Comp Cams XE line. It's P/N CCA-08-502-8, the main specs are:
218/224 @ .050
.528/.537 with the 1.6 LT4 roller rockers I have
112 LS
For reference the Hotcam is:
218/228 @ .050
.525/.525 with the 1.6 LT4 roller rockers
112 LS
The cam's are so close as far as the spec's go, it kind of seems like a wash to me. Right now the car has all the basic bolt on's. 2151 longtube header's, cat back, cut air lid, AIR pump elimnator, and a K&N. I am adding a converted LT1 intake, 1.6 LT4 roller rockers, LT4 valve springs, and a cam. All the parts are sitting in my garage except the cam.
The main attraction to the Hotcam is the price. They go for ~$150 on E-bay or the forums all the time. I also wouldn't have to buy new valve springs. If I get the other grind from Comp Cams, not only is the cam roughly $100 more, I'll need valve springs as well. Do you guys think there would be any appreciable difference in power production between the 2 cam? 300 RWHP is the goal, hopefully I get there.
I am wondering if the specs don't tell the whole story. What do you guys think?
Which cam would you choose and why? Or would you choose another cam all together?
Veaceonee
Sep 29, 2016 08:15 PM
loud91rs
Oct 5, 2015 10:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
tgp1990
Sep 4, 2015 06:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
