Throttle Position Sensor Adjustment
Old Jun 7, 2006 | 01:58 PM
PoppaCon's Avatar
Car: '92 Camaro RS
Engine: 3.1L
Transmission: Manual
I just replaced the throttle position sensor on my '92 RS. Now it's throwing a code stating the TPS is too low. How do I adjust it? There is no lever, it mounts flush with the throttle body assembly. Any suggestions?
Old Jun 7, 2006 | 02:23 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
you need to use a voltmeter, and loosen either top or bottom of the tps, turn the key on, find the output wire not sure which, Then set it to .54 volts closed throttle
Old Jun 7, 2006 | 02:31 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Every TPS for FI cars I've ever seen have a tang that has to be in contact with the throttle linkage. Most of the "low TPS" codes are either from incorrect installation or a bad TPS. I know you just replaced it but parts are known to be bad out of the box. Check the resistance of the TPS with the plug disconnected - if it does'nt change it's probably not engaging the throttle tang.
Old Jun 14, 2006 | 10:50 AM
PoppaCon's Avatar
Car: '92 Camaro RS
Engine: 3.1L
Turns out there is no adjustment for the tps on the 3.1L V6. The parts house gave me the wrong part! Once the new one was in it ran like a dream! Thanks for the input, though!
Old Jun 14, 2006 | 12:22 PM
Tmoney04's Avatar
What made you change your TPS? How was the car acting?
Old Jun 15, 2006 | 10:56 AM
PoppaCon's Avatar
Car: '92 Camaro RS
Engine: 3.1L
In warm weather (70+) the car would try to stall, felt like it was missing, and would idle sporadically. The only code was for the coolant temp sensor. I replaced the cts and that didn't resolve the problem. After researching the forums here I thought the most likely suspect (and easiest to fix) would be the tps. Long story short, after putting the right unit in, the problem is 90% better! Still has a couple issues (now it's throwing a code 53: system voltage too high), but it's much better than it was!
db057
Sep 4, 2015 07:57 AM
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 21, 2015 05:51 PM
