My timing is messin with me...
Old Jun 7, 2006 | 09:48 PM
1986Sleeper's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
Ive got a carb'd 305, 700R4, and q-jet, orignal intake, orignal cam, and HEI with vac. advance
Ive checked the vacum adv. it works, and the mechanical adv. it works to...
I time it at 8deg. then connect the vacum, and rev it, and its like its being held back, so i tried retarding it a bit, and rev it, and it revs much better, but when i shut it off, it desils...
So where should i time this thing EXACT...
Old Jun 8, 2006 | 12:11 AM
Draekon's Avatar
Car: 1984 Firebird
Engine: 305 LG4
Transmission: Automatic
I believe on my '84 firebird its 6* BTC with an auto @ 500RPMS and 8* BTC with a stick @ 700RPMS. Not sure if an '86 Camaro would be the same though.
Old Jun 8, 2006 | 12:28 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
why are you using the engine with no load on it for your "rev test" to see what the motor wants. Set the motor up for 32-36 degrees at 3000 rpm and let the intial fall wherever it does. This is with the vacuum can disconnected. Drive the car around and your dieseling problems should be gone.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
