Could VATS by my problem
Old Jun 8, 2006 | 06:36 PM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
Transmission: 5 speed
I have an 89 Camaro RS with a 5.0 auto. It started off not starting about once every two months. After about a year of that it started getting worse and now it won't start enough to call the car reliable to drive everyday. I've checked the starter and don't have signal (12+ volts) from the key but I have signal from the ignition. Now I have also jumped the starter by putting 12 volts from the battery straight to the starter. The engine cranked over but the fuel pump didn't activate nor did the injectors try to pulse, so that leads me to believe the secuitry system might be my problem. I installed resistors that match the key in the wires to bypass the key altogether. But still having the problem. Can anyone help? Any ideas what so ever I'm lost. Thank for your time.
Old Jun 8, 2006 | 06:43 PM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Your oil pressure sender may be bad. If your computer doesn't see oil pressure It won't send a signal to activate the fuel pump. Or maybe the fuel pump relay is bad. Or your fuel pump is bad. I may be wrong but it's a suggestion.
Old Jun 9, 2006 | 09:12 AM
89RS&98Z28's Avatar
Car: 1989RS////1998Z28
Engine: 305////350LS1
Transmission: 700R4////4L60E
And still no volts from key to starter?
Old Jun 9, 2006 | 03:52 PM
fastTbird's Avatar
Car: 89 Firebird
Engine: 5.7 TPI
Nope still no volts from key to starter
Old Jun 9, 2006 | 08:34 PM
89RS&98Z28's Avatar
Try checking ignition module . MOUNTED ON PASSENGER SIDE OF STEERING COLUMN at the bottem
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
