Heads and comp question.
Old Jun 9, 2006 | 02:12 PM
devilfish's Avatar
I got a pair of good new alu heads ( canfield) but with the "wrong" chamber size ( long story ).
With those heads (72cc) my comp would be around 8.9:1. With the 64c heads it would be around 9.7:1, and that is what I whant. How much power/throttle responce will I loose if I use those 72cc heads?
Is it worth to mill the heads to reach the desierd comp ratio?
Car is
canfield heads
hotcam
355 all forge
headers
Lt1 intake.
Old Jun 9, 2006 | 04:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
with a cam like that, it'll feel pretty sluggish at the low end. Good news is, you can use cheaper gas
Flat milling it should work, but that's a fair bit to mill off, may need to check intake manifold fitment then, and that gets painful. Call up your machinist and see how much it'd cost to mill them down to that.
Old Jun 9, 2006 | 05:14 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
ouch!
Thats going to cost a pretty penny to get them milled that much and have the intake milled to match. Then you will also have fitment issues later on down the road if you want to keep the intake and swap heads or swap intakes and keep the heads.
It would probably be cheaper to throw in some domed pistons...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
gixxer92
Sep 1, 2015 04:32 PM
mz92274
Aug 25, 2015 08:47 AM
Dialed_In
Aug 20, 2015 01:45 PM
