autolite3933 plugs
Old Jun 10, 2006 | 08:44 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
autolite3933 plugs
Is anyone using these plugs in a n/a engine? The speed shop i got my heads from suggested them but they seem too cold.
gw350 stock bottom, 190cc al. heads, holley 600, msd ignition, comp xe274
How far should the plugs stick into the heads? I ran them into the heads and they stick a little less than a 1/4 inch into the chamber.
thanks for any info.
Old Jun 10, 2006 | 10:18 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
I won't put anything but Delco plugs in my car. Too many years trying to diag some idiot's car only to find out a shop put in the wrong spark plug.
You can do it any way you prefer but at a minimum you should measure how deep the spark plug came into the old cyl heads by using a straight edge across the head and a very good Ruler and compare the same measurement with the new heads . If the plugs dont come in further than they did on the old heads you're safe
Old Jun 10, 2006 | 10:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hooga, do you have a cross reference to a delco plug? I can't compare that heat range off the top of my head unless it's a delco P/N.
FWIW, I went from an LG4, to my new hot 350, 10:1 iron heads (416's), and went 3 heat ranges colder, with a non extended tip.
Old Jun 11, 2006 | 05:25 AM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
Thanks for the replys. I'll measure the depth when i get them off today.
There is no cross reference for an ac plug. I looked thru autolites website and couldn't find one for that particular plug. I guess i will just have to pull one after running them for a while and see if they are fouling.
Old Jun 11, 2006 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The Autolite 3933 plug is from their racing series of plugs. Has a copper core and a cut back electrode. Is a gasket seat, 3/4" reach (the threaded portion), and 5/8" hex.
When inserted into the chamber the end of the threads should be flush with the chamber surface.
For some data points I use the standard Autolite 3924 plug. This is in an aluminum head. the stock plug for the Corvette's with aluminum heads is the 3926. What is a hotter plug then the 3924.
RBob.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
