Battery wont stay charged!
Old Jun 12, 2006 | 04:21 PM
gp423's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: open 2.73's baby!!
i figured id post this here since eletrical has to do more with accessories and wiring and such.
this has developed recently, the car will just die out of no where and i dont even have enough juice to spin the starter. i have a new battery and just replaced the alternator as i thought it was the problem.
im pretty sure the battery doesnt have a damaged cell because it will hold a charge when i jump my car. i think for some reason the computer is not telling the alternator to charge the battery. im a little lost as to ideas. all connections are secure and the belt is tight with very little play. please any suggestions would be great! walking to work sucks!! lol
oh also, i do not have any blown fuses if that helps.
Old Jun 12, 2006 | 04:33 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
How have you checked the battery? 12 volts across the terminals does'nt tell you much, you need to do a load test to see if its good or not. This is the test the parts store will do if you bring it in.
The computer does'nt have anything to do with charging the battery. Alternators from parts stores are notorious for being bad out of the box. If you can, take the car to a parts store that will test your battery and alternator on the car. If not, take both of them in and have them tested.
Old Jun 12, 2006 | 08:58 PM
gp423's Avatar
Engine: LB9 305 tpi
alright ill give it a shot i just put the dam alternator in! peice of crap! lol, oh well its only like 5 bolts, too bad 2 of them are stripped to hell! thanks for the suggestions, do these tests cost anything?
Old Jun 13, 2006 | 07:31 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Should be no cost at a parts store.
gta892000
Aug 11, 2019 11:16 AM
z28joe2
Sep 28, 2015 05:54 PM
Johnoooooo
Sep 22, 2015 08:55 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
