Is there a "common" cause of running rich?
Old Jun 12, 2006 | 06:15 PM
Scotty27's Avatar
Car: 1989 IROC
Transmission: t5, wanna be a t56 when I grow up!
Axle/Gears: Whatever stays bolted on behind me!
Just got back from the sniffer, failed. High HC, grossly high on CO. NOx low, as anticipated. Running rich. Did some searchin, reading.... Is there a culprit more common than others as to make a car (ours) run rich? Passed NP 2 yrs ago, no SES light (aside from 32, which seems to be repaired with new temp sensor), NO hesitation, sometime purging idle, once n awhile rough acceleration, came and went on its own twice. 141xxx on the ticker, no mods beyond flowmasters, new O2 sensor July of 04 (no SES...) I see tests for the TPS which I can do, also plan on changing plugs and at least inspecting cap/rotor/wires. Would leaky valve guides/seals and burning a little oil be cause for high CO? (Stooopid question) how does one wash/clean a K & N filter? Is it as simple as flushing with water and air drying?
Here were my readings:
READING LIMIT
HC 1.605 gr/mi .800
CO 36.6212 gr/mi 15.00
Thanx guys!!!
Old Jun 12, 2006 | 06:55 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Possibly time for a new O2. What brand was it if you remember?
Some brands are supposed to read a bit differently causing it to run rich enough to get you a fail on the sniffer.
Bosch i believe was the sensor of choice but i may be wrong.
Old Jun 12, 2006 | 07:29 PM
Scotty27's Avatar
Car: 1989 IROC
No dont remember brand, prolly whatever NAPA sells
Old Jun 13, 2006 | 03:31 PM
Scotty27's Avatar
Car: 1989 IROC
Anyone else?
Old Jun 13, 2006 | 03:50 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
buy bosch they are a really good company we use them as much as we can for parts at my work and it never fails.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
