Down on power
Old Jun 14, 2006 | 02:29 AM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
Down on power
Ok, my formy has been down on power. Adjusted the rockers, that helped. I changed the fuel filter today, then checked the FP. It pulled 45 PSI, which is dead on from what I understand. The problem is the car is seriously lacking up top. I know that TPI is not known for up top, but it should still pull better than it does. I still need to change the cap, rotor, and coil. The car is also still bogging down when I go full thottle. The RPM's go up, but the car doesnt go. I also noticed that if I am running around 40 mph, and I mat it, it only jumps to about 3500 RPM. Any ideas?
Old Jun 14, 2006 | 12:38 PM
Tmoney04's Avatar
sounds a lot like my problem. check out my post on "just bought 88 GTA...." for some ideas. I am going to check my cat for damage/clog tonight. Is your service engine light on?
Old Jun 14, 2006 | 11:07 PM
puffcat's Avatar
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Transmission: manual
Axle/Gears: posi
If it's not your cat it's your timing chain and or camshaft. Pray it's the timing chain if it's not the cat, which I doubt it is. Chain is easy to replace, you just need a saturday, some coolant, and oil cause you may need an oil change afterwards.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
