Surging problem.
Old Jun 15, 2006 | 12:02 PM
James Brine's Avatar
Surging problem.
If any of you can figure this one out, I would be REALLY grateful!
I have a 1982 Camaro with a new 350 GM crate 5.7 liter, carbureted, with the timing around 12 before top dead center (although I set it without disconnecting the vaccum advance as I don't know where it is to disconnect it). The problem is this:
You drive the car around town not going above 55 and all is fine......then you take it on the freeway and while you are accelerating up to 65-75 miles an hour all is still fine.......but when you let off the throttle a little and even out at 65-75, the car surges quite badly. If you start to accelerate again, it smoothes out until you level off. What could be causing this? Is it an air/fuel delivery problem, timing, carburetor set funky? I have no idea what it is. The car is absolutley great otherwise.
If any of you out there have an idea, I'd love to hear it!
Thanks,
James.
Old Jun 15, 2006 | 12:12 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Check
Check you fuel pump. That what mine was on my 85 Carb truck. Also EGR valve.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
92camaro350cci
Oct 14, 2015 09:29 AM
HoosierinWA
Oct 7, 2015 10:15 AM
banksGTA
Sep 13, 2015 11:56 AM
