One Plug (#7) black, all others just fine!?!?
Old Jun 17, 2006 | 10:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I rechecked the plugs tonight after another start and found that they all look clean but #7. Its black and I don't have a clue why. Car doesn't feel to run on 7 cylinders but its new so I wouldn't know for sure.
Heres a pic...car is a 383 with the Stealthram, trickflow heads and a 230/236 .544/.555 comp cam and 30# injectors.
Old Jun 17, 2006 | 10:27 PM
Bird1994's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI - Yeah... That's gotta go
Is there any possible way the bore is off
Old Jun 17, 2006 | 10:31 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I don't think so. The original owner/builder of the shortblock got all the machine work done and it all looked good and professional.
Who knows though.
Old Jun 17, 2006 | 10:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Just thought of something, try putting your timing light hookup wire on your #7 plug wire, that'll tell you if it's firing.
Old Jun 17, 2006 | 10:38 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Also, going with what I said in the previous thread, try activating the pump, then as the pressure is dropping with the pump off, pinch off the return line to the tank... The dropoff should stop if its a bad regulator, pump checkball, etc.. If it continues, maybe leaky injector..
Verifying spark on that cylinder would be a good step 1.
Old Jun 18, 2006 | 12:38 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I don't remember what post I said it in but I tried to pinch off the lines and can't because they are braided steel lines. I have an inline spark tester I will mess with when i fire it up again after I set the timing a little better.
heres a closer pic of the plug
Old Jun 18, 2006 | 12:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
yep, black as tar alright...
I was just curious if you could see if it was fuel or oil.... Does it smell gassy or oily? (probably both I'd guess...)
Old Jun 18, 2006 | 12:53 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Hard to tell. What could cause this if its firing and the injector isn't leaking?
Old Jun 18, 2006 | 11:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Lots of blowby due to poor ring seal. Ring could have been installed "wrong" somehow, leading to blowby, and wearing excessively, showing much metal shavings in oil. That's a total WAG, but who knows...
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Mar 18, 2019 08:29 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
