HELP!! '94 z28 security light blinking/won't start/was fine last night
Old Jun 18, 2006 | 06:10 PM
rockstar1219's Avatar
I have a 1994 z28 camaro..got in my car this morning and turned the key AND NOTHING HAPPENED..Never had problems before..always starts right up...I DID HAVE FULL BATTERY POWER...new battery,all the lights come on and everything else works...makes no sound when i try to start as if it was dead..MY SECURITY LIGHT FLASHES WHEN I TRY TO START CAR & WHEN KEY IS TURNED IN THE IGNITION...thought it my be my starter at 1st but i hope not...i have read on the internet today about a possible VATS problem...all fuses and look good..cleaned off my keys..the damn car was running fine last night..HELP!!!
Old Jun 18, 2006 | 06:38 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I really do not know a whole lot about VATS and all that jazz... disconnect the battery for 5 minutes and hook it up again.... then try to start. Should clear any gremlins
Old Jun 18, 2006 | 08:16 PM
camarokev400's Avatar
possibly have a broken wire in the column up my the ignition cylinder, 2 wires run from the base of the column up to the ignition cylinder for the vats. Tey are usually wrapped in a orange sleeve and there should be 2 white wires inside, easy way to tell is check for resistance across the connector at the base of the column, or remove the steering wheel/turn sig switch and look for the broken wires right near the cylinder itself.
Old Jun 18, 2006 | 10:31 PM
ShawnPennington's Avatar
Car: 84 z28, 86 firebird, 91 camaro RS
Engine: 84 350,86 V6,91 305
after taking the battery out and putting it back in. if that dont work with the battery in cycle the key about 15 times on off on off.
Old Jun 19, 2006 | 07:05 PM
wont do any good if those wires are broken
Old Jun 19, 2006 | 07:13 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Lock the door, and then open the door with the KEY (not the remote opener) and put your key in the ignition and try to start it.
VATS tweaks out on 94s at times, my old 94 T/A did the same thing and that's what fixed it when it tweaked.
If that don't work try disconnecting the battery for about 10 minutes and trying again.
Old Jun 19, 2006 | 09:23 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
even my boss's brand new minivan will do the same thing. door has to be opened by key or else it has to be both opened and started by remote. weird...
Old Jun 20, 2006 | 07:35 PM
1986-T/A's Avatar
Car: 1986 Trans Am
Engine: 1963 Corvette 327/420hp
Axle/Gears: stock
The security feature on most vehicles is equipped to one key a lot of times if you use a different key the car will not start even if you disconnect the battery, lock and unlock the doors and anything else that makes you feel like it helped out, I'm not very familiar with a 94 camaros security feature but this might be the problem. If you have another key try it out, maybe it will work out for you. A lot of people make this mistake and do not even realize it. If you have a chip in your key this is most likely to be your problem, broken wires, bad pcm's and a few other things tend to happen but most times this is the problem.
pimp2303
Jul 27, 2017 02:03 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tonyy_z
Aug 12, 2015 07:20 AM
Omega
Aug 10, 2015 12:46 PM
