91 z28 305 to 350 block?
Old Jun 19, 2006 | 08:45 PM
fg_stadium's Avatar
can I have my 305 bored out to 4.000 like a stock 350?whats the difference between the motors?also can I use a 1986 350 block with the stock computer and all?
Old Jun 19, 2006 | 08:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, you can't bore a 305 out to a 350. If you tried to bore it out that far you'd have no walls left and you'd be into the coolant passages.
Old Jun 19, 2006 | 08:52 PM
fg_stadium's Avatar
can I swich just the 305 block to a 350 block and use everything from my 305 on it?
Old Jun 19, 2006 | 09:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Most 305 parts can be used on a 350. A few need to be changed. It depends which engine you have now. If you do a search, this gets covered all the time.
Old Jun 19, 2006 | 09:07 PM
fg_stadium's Avatar
I was wondering if the tpi intake set up and the 305 headers would fit the 86 350?I know the heads will fit but will it all work out good?
Old Jun 19, 2006 | 09:27 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
As long as you use the same heads or any other 87+ head the TPI will bolt on without and modifications.
Headers are all the same. a SBC is a SBC (other than the oddball D port heads), it doesnt know or care what its on!
What do you plan on doing with the motor?
If you plan on making high RPM power you should seriously look at ditching the TPI, its a great system for lower RPM but falls on its face in the higher RPMs (4500RPM+) unless you port it out, but it would still be lacking.
Old Jun 19, 2006 | 10:12 PM
fg_stadium's Avatar
motor
I'm a torque freak and not into high speeds,it's gonna be a daily driver with alittle attitude,I mostly stay in the idle to 5,500 rpm range when I build my motors?so should the tpi stay or the carb be put on?
Old Jun 19, 2006 | 11:40 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
If your just going for the bottom end torque keep the TPI. They are torque monsters!
Old Jun 20, 2006 | 08:05 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
if you want to use a 350 block with your 305 rotating assembly you have buy new pistons. your rods and crank will work but the factory balance on a 305 crank is a little different than a 350.
As far as using the heads of a 305 the intake valve is a bit smaller and the combustion camber is also smaller along with the runner volume.
You will get higher compression with a 305 head due to the combustion camber volume of 58 but you will have to be carefull of the piston to valve clearance. Clay the motor for clearnance or you will be sorry!
Old Jun 20, 2006 | 09:23 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
As long as you dont run big dome pistons, which you wont be able to if you use the 305 heads their will not be any valve-piston clearance issues. But its always better safe than sorry, check it out, ya never know if someone had those heads milled or that block decked.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
