bore?
Old Jun 21, 2006 | 11:04 PM
dang305's Avatar
bore?
i have an 89 rs with wimpy little 305, thinking about getting it bored out to a 350... any opinions? id be able to keep most everything right? n what heads should i get if i do it
Old Jun 21, 2006 | 11:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
not possible. do a search, comes up too frequently to be discussed in detail.
in short, buy a 350 block.
Old Jun 21, 2006 | 11:29 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Largest you could bore/stroke to would be a 335.
Old Jun 21, 2006 | 11:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Its not possible!
By the time it had a 4" bore in that 305 block the cylinder sleeve would be gone and you would be into the water jacket!
If you want more cubes you can build a stroker or just go buy a different block, your not going to do any substantial cube increases from boring a block!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
FormulasOnly
Jul 23, 2018 08:47 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
hartsmike
Oct 2, 2015 07:11 AM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
