Bad Vibration
Old Jun 21, 2006 | 11:15 PM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Bad Vibration
Today I had to lock up the brakes for about 10 feet causing the tires to smoke. After that happened, I noticed the car was vibrating bad. Im scared I wore down the tires and created a flat spot
I dont think it could be the driveshaft, but I'm definately going to check the yoke tomorrow.
Anybody have a clue as to what might have happened?
Old Jun 21, 2006 | 11:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You car is hot.
There, it had to be said.
You shouldn't be able to get a flat spot on the tires that quick. Something probably shifted, and now is out of balance.... Trans mount comes to mind. Maybe some rear suspension that is loose?
Old Jun 21, 2006 | 11:35 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Torque arm bushings?
Old Jun 21, 2006 | 11:41 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Originally Posted by Sonix
You car is hot.
Haha. What do you mean my car is hot..
And yea tomorrow I will check out everything. thanks
Old Jun 22, 2006 | 08:43 AM
Sonix's Avatar
Car: 1982 Trans-Am
sexy. red w/ black wheels. Very hot.
69GTOby
Apr 18, 2016 02:34 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
sac92transam
Oct 7, 2015 02:31 PM
InfinityShade
Sep 18, 2015 08:32 PM
gta892000
Sep 16, 2015 12:40 AM
