heater core in an fbody with a/c
Old Jun 23, 2006 | 12:44 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
first off can i say what a big pain in the ***. it wasnt my own car but damn it was not worth it even though it was my aunts. it took my from 9am to about 3 4 in the afternoon to change her heater core. it was all good removing the center console and the radio pod and dash pad but after that it was hell. bolts under the hood and plastic boxes that you have to take off. bolts were not easy to get to either. removing all the underside plastics and dropping the passenger side of the dash was just rediculous for the actual 5 minutes it took to replace the stupid damn heater core. i refuse to ever do it again and putting it back together was just a whole other story it was a bigger pain in the *** with old broken parts and making everything fit which wasnt that easy on her damn 88 notch. now i refuse to ever do it again even on my own car. to all of you that do it good ****ing luck and have lots of spare time on your hands.
Old Jun 23, 2006 | 03:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Other than showing your prowess at the rules-violating skirting of the board filter, what's your point? We already know replacing the core is a pain.
Old Jun 23, 2006 | 03:58 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
why did U remove all of that, all you have to remove is the pass. side hush panel, and use a 1/4 drive deep well socket with a short extension to remove the box cover, and then use the same setup W/ the next size down socket to remove the retaining bands and then pull it through the firewall, I've had to do it on both of my camaros and my trans am, 30 min tops...and yes all 3 cars have/had A/C
Old Jun 23, 2006 | 06:02 AM
EvilCartman's Avatar
Car: '82 Z28
Yup, you took the long way of doing it.
Old Jun 23, 2006 | 11:18 AM
Engine: LO3
damn now i feel stupid i shouldve checked here first i played it as i thought i needed. wish i did it the short way. i was just showing my anger towards doing this cause i thought itd warn other people but i guess i did it wrong so nevermind.
Old Jun 24, 2006 | 02:09 AM
Car: '82 Z28
Hey, at least it wasn't an 88 Ford Taurus, the heater core in that takes about 7 or 8 hours to do. Sometimes even more depending on the person.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
