This should be an easy one..............
Old Jun 23, 2006 | 11:05 PM
recaroguy's Avatar
Old Jun 23, 2006 | 11:09 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Not too familiar with the cross fire injection engines, but obviously, one of the injectors is extremely clogged or just dead.
Try taking it out and cleaning it with some carb cleaner and see if that clears it out. Also, you could try running a can of Seafoam through the gas tank, and see if that helps any. If that doesnt work, then you are going to have to get a new injector. I'm not sure if they are the same as the EFI ones, but if not, you are going to have to find a retailer online that sells them, or take a trip to the scrap yard.
Old Jun 23, 2006 | 11:50 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
[quote=GuitarJunki17]Not too familiar with the cross fire injection engines, but obviously, one of the injectors is extremely clogged or just dead.
I agree with GuitarJunk...if this doesnt help .I know the cross-fire Vettes had similar problems...I want to add some more if it doesnt.Make sure your fuel pressure is good..and if those check out.Your either into wiring,computer(injector driver bad) or a bad PROM.Good Luck..
Old Jun 24, 2006 | 12:39 PM
recaroguy's Avatar
Old Jun 24, 2006 | 01:33 PM
I HIGHLY doubt it is your computer or prom. I have never heard of them taking a dump and causing one injector to not work. There is really no way to "check" them as to my knowledge. Start small, don't worry about your computer for now.
Old Jun 24, 2006 | 11:13 PM
copperhead110's Avatar
I'm unfamiliar with cross fire injectors but....
to check wiring, connectors, computer, or whatever else is involved.
You could swap the working and non-working injector.
If the problem follows the bad injector to its new home, then the injector is bad.
Old Jun 25, 2006 | 12:51 AM
recaroguy's Avatar
armybyrd
Sep 28, 2023 12:16 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Gunner242
Dec 25, 2015 04:49 PM
92projectcamaro
Dec 8, 2015 12:25 AM
3.8TransAM
Oct 1, 2015 07:47 PM
