to time or not to time
Old Jun 24, 2006 | 06:44 PM
redcar's Avatar
My 1988 firebird had been hit in the front end some years and the body shop replaced the front clip and the hood. When these items were replaced the shop didn`t reapply the tag that has the EGR system and ignition timing values. At this point I am timing it by the seat of my pants, but I would like to know the proper timing numbers. I have tried my local GM dealer, with no success. I also have tried a U.S based site with limited success, they want you to buy the replacement tag, ( the numbers are on it ). Is there anyone out there that can give me the right numbers for timing. The engine is an "E" code 5.0l with a TBI and a 5 speed. TXS
Dave. please send 411 to dscott41@cogeco.ca
Old Jun 24, 2006 | 10:03 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
6* before TDC with the EST bypass wire unplugged
Old Jun 24, 2006 | 10:13 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
crank it up to 12 and run only 93 or higher octane, other wise it may diesel. you migh be able to squeeze a few more degrees but you'l loose performance faster
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
