New engine - "Snapping" noise
Old Jun 26, 2006 | 12:55 PM
TIE1-ON's Avatar
Car: '92 Z/28
Engine: 355 HSR, Hooker LTs, Dynomax X
I've searched the threads tirelessly and couldn't find something on this, so here I am.
I just installed my rebuilt engine.
1992 Z28 TPI
355
Holley Stealth Ram
Twin 58mm TB
Comp Cams 230/236 @ 113
Performax 64cc ported aluminum heads
30# injectors
All new internals (crank, rods, bearings, pistons, etc.)
Basically everything is new except for the block
First startup the engine has this "snapping" noise. Sounds just like someone taking a yardstick and smacking it on a table. It is continuous and rhytmic (meaning it stays constant at the same rate even when the engine warms). It improved somewhat as I dialed the timing down closer to TDC with the timing light, but it's still there. Sort of sounds like a spark plug arcing. I have new MSD wires, MSD rotor, and new plugs. I checked the plug wires and don't see any arcing.
Any help would be appreciated. Thanks.
Old Jun 26, 2006 | 01:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
snapping like electricity? or snapping like rocker arms not being adjusted properly? I would start the car at night in a completely dark room and see if you see arcing anywhere, it'll show up as a blue light.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
