RWHP VS. Crank HP??
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
RWHP VS. Crank HP??
what is the % lost when measuring hp @ the crank in relation to hp @ the rear wheels?? Is there a formula to convert?
Transmission: 4L80E/4L80E
There are estimates, but no formulas because of variations from drivetrain to drivetrain.
No. The only way to know is to have your engine run on an engine dyno and then run it on a chassis dyno.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Theres a General estimate, and that estimate is:
20% loss for your average automatic drivetrain
15% loss for your average manual drivetrain
These arent meant to be 100% accurate, rather, just give you an idea.
One way to reduce this loss is to get a light driveshaft. Aluminums are popular, but about 400$ new. You could also opt for a carbon fiber driveshaft, which only weigh about 3-5lbs! That's about 80% lighter than your stock driveshaft, but be aware your wallet will also be 85% lighter.
skinny z
Oct 5, 2015 06:23 PM
