Could it be bad timing.
Old Jun 27, 2006 | 10:49 AM
Z28Mike's Avatar
PUUURs Like a kitten at Idle. Runs like a 3 legged dog whenever some load is aplied. Between 2200-2600 rpm the engine seems to bog/not fire, after 2600 rpms the engine runs ok,,,,but when I get on it kinda heavy ( like getting on the highway at 3500 rpms) itll do the same thing it was doing at 2200-2600 rpms,,,,,kinda bog down a little bit-I see it in the tach and feel it in the seat.
while replacing my injectors last night I noticed that a vacuum hose coming off the charcoal container was cut all the way through, it looks like it had been routed behind the alternator. I looked at the autozone vaccum diagram and it didnt help. All it showed for the hose was a dotted line going to nowhere. Im grasping for straws gentlemen. Ive relpaced my fuel filter, plugs, wires, cap, rotor, injectors, tps, egr, O2, and my car is still running like a turd.
91 Z28, 5.7, TPI
Old Jun 27, 2006 | 11:15 AM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
The hose connects to the throttle body. If it's the little hose I believe it's on the bottom left, if it's the big hose it's on the right side behind the IAC.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
customblackbird
Oct 1, 2015 04:30 PM
gta892000
Sep 16, 2015 12:40 AM
