Weirdest possible oil leak I've ever seen...
Old Jun 28, 2006 | 08:48 AM
spifman's Avatar
Car: 1986 Camaro RS
Engine: 305 V8
Transmission: 700r4 automatic
So I'm going to change the fuel filter in my car last night, and as I take off the wingnut for the air cleaner, I feel it's covered in oil. Nowhere else that I can see in the engine compartment is covered in oil. I pull the dipstick and check the oil level, comes out dry 3 times in a row. It's been running fine, no oil spots on the pavement, just no oil. I fill it with 3 quarts of oil and 1 bottle of "stop leak" (with it being an old engine anyways, figure it can't hurt things), run the engine to let it flow, no problems/no leaks.
Today, after I get to work, I pop the hood and check, and it looks like there's smoke coming from around where you add oil (I spilt a little bit last night, and I'm not sure if it's just burning off or what). It's also pinging a bit, kind of like when water hits a piece of metal, but not sure if the 2 are related.
Any ideas? I'm planning on getting a full engine gasket replacement kit and replacing everything, but wasn't planning on doing it until August (I'm inexperienced at it, and it'll give me a long weekend to sit down with the shop manual and figure it out).
Old Jun 28, 2006 | 09:49 AM
ckeene502's Avatar
oil leaks are a pain!!!try cleaning the engine bay a best you can, removing caked oils spots and such. then see if any come back. thats crazy oil on top of the lid.
Old Jun 28, 2006 | 10:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is your PCV system working?
Old Jun 28, 2006 | 11:22 AM
spifman's Avatar
Car: 1986 Camaro RS
Engine: 305 V8
I thought it was. I changed out the PCV valve not too long ago, and I saw a dramatic increase in engine performance. I might pull it out, see if it's covered in oil or not.
Old Jun 28, 2006 | 12:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
run some seafom and or water through a vacuum line too. The magic cure all.
Old Jun 29, 2006 | 09:18 AM
spifman's Avatar
Car: 1986 Camaro RS
Engine: 305 V8
I pulled the PCV Valve and replaced it (for $2, why not?) and it had oil on it. Bad sign?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
