cam help??
Old Jun 30, 2006 | 02:22 PM
fg_stadium's Avatar
cam help??
I have a 91 z28 305 tpi and I'm confused on the types of cams I can use,can it be a flat tappet or does it have to be the roller?whats the difference between them?
Old Jun 30, 2006 | 02:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you can, and should, buy a roller cam.
a flat tappet would work, but you'd lose efficiency, have to buy new lifters, and pushrods. With a new roller, all you'd need is the cam.
The cams would look similar, if sitting next to each other on a table, the difference is in the type of lifters you use, either flat tappets, or rollers.
Old Jun 30, 2006 | 07:30 PM
fg_stadium's Avatar
whats the difference between the mech. and hyd. cams?which one would be better if I kept the stock lifters?
Old Jul 1, 2006 | 01:34 AM
Sonix's Avatar
Car: 1982 Trans-Am
if you keep stock lifters, those are hydraulic, so you'd need to use a hydraulic roller cam.
If you went mechanical, then you'd get mechanical lifters to go with your new mechanical lifter cam. I don't think thats what YOU want.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
